Sponsored by: Real Truck
possessed F350??
Old Jun 3, 2009 | 11:15 AM
iamlance's Avatar
iamlance
possessed F350??
Hey all,
I own a auto repair shop in Ct. A customer brought in his 05 F350 Super Duty 4X4 5.4, 47000 miles with an unusual complaint. While driving along the front end begins to pull hard left or right. It happens infrequently and on various road surfaces. It has happened on straight, smooth roads as well as rough surface curves. He fights the wheel to keep the truck on the road until he can pull to the side. Once stopped, he rotates the steering wheel lock to lock, hears a click or clunk and drives off with no problem. I had the truck for 2 days, drove it frequently and had no problem. I put it on the lift, checked all steering and suspension componants and no problem was found. I rotated the steering lock to lock using the tire and all was smooth and steady. I really wanted to feel the problem on the road as my description may have differed from the customers, but no luck. I showed the customer a service bullitin regarding wheel occillation, but he said that description was not what he expirienced. He drove the truck home (10 miles) without incident but is reluctant to continue driving. Any ideas?? Thanks.
Old Jun 3, 2009 | 01:49 PM
BillyBob69's Avatar
BillyBob69
Crawl underneath and check while the wieght is on the vehical. The suspension sits differently on the ground than in the air....Unless of course your lift picks it up by the tires.
Old Jun 3, 2009 | 03:37 PM
bpounds's Avatar
bpounds
Might be power steering related, rather than suspension.
Old Jun 3, 2009 | 03:52 PM
Ballswedge's Avatar
Ballswedge
Ball joints? Tie rod ends?
Old Jun 3, 2009 | 06:06 PM
Fordfanatic4life's Avatar
Fordfanatic4life
i'd bet its a balljoint problem that will only show up when the tires have weight on them...
if the balljoints dont have Zerk fittings i'd bet they are still originals and prolly dry as a fart inside by now...
Old Jun 4, 2009 | 08:55 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Either that, or it's another steering-box issue with the spool valve leaking internally.
Spooky how many of these are showing up recently.
100-10x
Nov 21, 2015 01:34 PM
Headviking
53
May 25, 2014 03:44 PM
JLS TRUCK
23
Jun 20, 2013 07:31 AM
Adobe 11SD
6.7L Power Stroke Diesel
Dec 20, 2011 05:05 AM
onebighangoverguy
May 12, 2011 08:38 AM
