Offset And Backspace
Old Jun 3, 2009 | 08:36 AM
donbeeler49's Avatar
donbeeler49
Question Offset And Backspace
I have a 2007 FX4 and am going to buy aftermarket wheels. I will run 33" tires and both rims are 18x9. One rim has 5" of backspace with 6mm of offset. The other has 6.25 of backspace with 19mm of offset. With 2" of leveling in front, which rim will fit better without rubbing either the inside or outside? Please help!
Old Jun 3, 2009 | 03:22 PM
donbeeler49
Question Offset
If nobody can answer this question than can you guys that have aftermarket wheels in 18x9 size tell me the offset and backspacing you have without rubbing issues. I will be running an AT tire so side biters or ***** won't be an issur. Thanks.
Old Jun 3, 2009 | 06:05 PM
deisele75's Avatar
deisele75
I have 17" Procomps with 4" of back spacing 2 1/2 leveler. Im running 305 60 R17 (And I do have Side biters).
Lock to lock with full articulation and no rubbing. Pics in my gallery if you want to see how it looks.
pkthomas
Nov 16, 2016 11:36 AM
FordF100man
Nov 7, 2015 01:52 PM
SteveJH
Sep 18, 2013 09:40 PM
Rob102582
May 29, 2013 09:26 AM
