86 6.9 lift pump problem
Old Jun 2, 2009 | 10:21 PM
murrhee's Avatar
murrhee
hello, i went to the ford dealer and ordered a new lift pump and when i pulled the old pump out it is bent at a 45 degree angle and the one i got from ford dealer looks strait on the part that goes in the block, is there two dif. pumps, and do i need to take it back and get the bent type. thanks for any help on this one.
Old Jun 3, 2009 | 07:21 AM
Lazy K's Avatar
Lazy K
The new pump you got is OK. There should be detailed fitting instructions with it which you must follow exactly. It is a real PITA to fit. If you scroll thru a few threads here you should come to a recent one by joe f350 on fitting one of these pumps, I think it took him a day.
Good luck.
Old Jun 3, 2009 | 10:27 PM
murrhee's Avatar
murrhee
lift pump
thanks,i will see if i can see up in there with a mirror and get that lever under the push rod this weekend, thanks agin, that original pump sure does look way different.
Old Jun 3, 2009 | 10:29 PM
joe f350's Avatar
joe f350
it took a day but my truck is lifted makes it hard to more on the underneath
