Sponsored by: Real Truck
no 4 wheel drive
Old Jun 2, 2009 | 03:31 PM
rockcrawler_101's Avatar
rockcrawler_101
no 4 wheel drive
I have been reading up after searching a bunch but it seems like i have two problems keeping my 4 wheel drive from working! I grounded out the relay and got 10 volts to the motor but no motor turn. Then i checked the volts at the motor with just the switch kicked over and got nothing at the motor! Please help!
Old Jun 2, 2009 | 03:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
OK, a few things to check out.
First, put a test light (or meter) on the wires going to the shift servo (motor). Then, with the engine running, have someone cycle the ESOF **** back and forth between 4x2 and 4x4, waiting 10 seconds between cycles. See if you get any voltage there. The shift servo should get voltage only for about 10 seconds, and then it quits so it's kinda hard to figure out if you have power there by yourself.
If you have no voltage there whatsoever, it sounds like the shift relays. There are two of them, the first thing you might want to try is to swap them and see if it goes into 4x4. If it does, swap them back so you can get back out
krewat's Avatar
krewat
Old Jun 2, 2009 | 03:48 PM
rockcrawler_101
Relays are good. I can feel them click when i grounded them out. Thats some good info on how long it will try to click over i will have to check that out. Thanks!
Old Jun 2, 2009 | 07:14 PM
rockcrawler_101
ok still no power at the shift motor.
