lift and shackles, Is this okay?
Got a 04 ford 350 diesel. Already have a 4" procomp lift with pitman arm and drop bracket. Wondering if it would be okay to ad a 2 1/2 inch shackle lift to the rear of the spring as well. I've just installed it and need longer stabelizer links. In my search for stabalizer links I was told that this is not safe to have the lift and the shackles. Somthing about the pivot angle. I didn't quite understand what the guy was saying. Any thoughts or suggestions on this?
I would do it right and get larger springs. The shackles will be more problems and cause the springs to dearch faster. Please tell me if you used shackles you got a decent set... Flimsy shackles and a decent load will spell trouble. A good properly designed lift will make the truck a pleasure to drive when you piece it together and do do it correctly its a time bomb with either part failures or possible injury.
