c6 soft second gear shift...
Old Apr 23, 2002 | 04:35 PM
Rayjon1's Avatar
Rayjon1
I have an 81 f250 400m c6 combo. The problem is that it shifts into second really soft... I was going to tighten the second gear band and see if that helps anyone have any other ideas?????
Old Apr 23, 2002 | 09:47 PM
Like M. Fords's Avatar
Like M. Fords
Since it is this band that gives you the 2nd gear, I would try that first also. Besides, it is the only external adjustment you can do besides the linkage. In case you don't know the procedure, loosen the locknut, tighten the adjusting screw to 10 ft-lbs and then back it off 1 turn. Hold the adjusting screw while you tighten the locknut 35-45 ft-lbs.
Old Apr 24, 2002 | 07:41 AM
vanner's Avatar
vanner
