shift kits
Old Apr 20, 2002 | 03:34 PM
79_ford_400_guy's Avatar
79_ford_400_guy
shift kits
hi i have been hearing a lot bout shift kits lately from my friends and was wondering what it really does?????/ and how hard it is to install thanks kevin
Old Apr 24, 2002 | 07:41 AM
vanner's Avatar
vanner
shift kits
I put one in a e40d the other day it wasnt that hard. it was the B&M kit from summit.It shifts a little harder but better doesnt search for a gear when you let off the gas and the MPG's went up about two miles per gal. Keep things clean if you do it torque the valve body to In.Lbs not Ft.Lbs. same with the pan and put a drain plug in while your at it good luck.
Old Apr 24, 2002 | 05:53 PM
kennethl6's Avatar
kennethl6
shift kits
