Finished stainless up pipes
Old Jun 1, 2009 | 09:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I mentioned to some of you i was making new up pipes, and you wanted pictures. I wish i would have taken pictures along the way, and such but oh well.
Old Jun 1, 2009 | 10:03 PM
mueckster's Avatar
mueckster
That'll work! Looking good.
Old Jun 1, 2009 | 10:25 PM
CSIPSD's Avatar
CSIPSD
Looks good, be careful of the welding slag inside the tubes, and you might pressure check them too.
just some ideas for you.
Old Jun 1, 2009 | 10:28 PM
PowerstrokeJunkie
I used an engine to mock them up, and then tacked the S out of them, then finished welding them off the engine. I ground down the joints where i could looking for missed spots, saw none. Once they get back from the coaters i'll find a way to pressure check them, or just look for soot once it has been run
Mine was a little more complicated to get the passenger side, i used a 135* bend and a 90* bend to get them to work, as my turbo sits at the same angle as stock, uses a stock style downpipe. Did you use mild steel? 304 didnt hold up for me on the other set
Old Jun 1, 2009 | 10:36 PM
WA.Ranger's Avatar
WA.Ranger
Very nice............
Old Jun 1, 2009 | 10:39 PM
CSIPSD's Avatar
CSIPSD
Mostly stock pieces of SS with a few bends of 304... Working well so far! Your turbo must be a Garrett or S-300 type? Holset snails are too long to use the factory down pipe...
My next kit will use a factory down pipe.
Old Jun 2, 2009 | 02:26 AM
Visseroth's Avatar
Visseroth
You make me jealous!!!
Old Jun 2, 2009 | 05:39 AM
King0581's Avatar
King0581
Nice, Stainless stuff really catches my eye! Why didnt the 304 hold up for ya?
Old Jun 2, 2009 | 05:54 AM
Adam0331's Avatar
Adam0331
Lookin good Kris.
Old Jun 2, 2009 | 07:37 AM
03_PSD's Avatar
03_PSD
Really looks good Kris. You da fab man!
Old Jun 2, 2009 | 08:21 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Those should last a long time. You only have 2 places for a leak, instead of 4. When can we start ordering them from you.
Old Jun 2, 2009 | 08:34 AM
big poppa's Avatar
big poppa
That is pretty wicked, personalized thats for sure.
Old Jun 2, 2009 | 08:49 AM
King0581's Avatar
King0581
Man, if I only had a 7.3 laying around 2 mock a set up by......
Old Jun 2, 2009 | 04:58 PM
PowerstrokeJunkie
Thanks for the compliments. I like fabbing stuff
It is a T6 kit, not a T4. I have an S400 frame charger, no i did not make the pedestal, i just recreated the up pipes. I hit 22, 2300 or some outrageous EGT, and the 304 heated up to the point where it bent, and the pipe was rubbing the head, the bellows were stretched and leaking drive pressure. These 321's have more resistance to heat, plus the 2000* ceramic coating will help spool this bitch.
Old Jun 2, 2009 | 06:13 PM
King0581's Avatar
King0581
Damn! I forgot for a second that you had all the modifications. Yeah I'd say 22-2300 would mess up some 304.
