turn signals stopped working
Old Jun 1, 2009 | 09:07 PM
1993 E-150's Avatar
1993 E-150
my turn signals stopped working in my 93 e-150, i checked fuses they're fine, i installed new relay, still not working. i need help please
Old Jun 2, 2009 | 08:28 AM
Franklin2's Avatar
Franklin2
Do they light constantly, but not blink? Or nothing happens at all? Do your brake lights work?
Old Jun 2, 2009 | 03:37 PM
1993 E-150's Avatar
1993 E-150
no they don't light or blink and yes i have brake lights
Old Jun 2, 2009 | 04:28 PM
Franklin2's Avatar
Franklin2
Here's a diagram, look in the lower right corner.
http://repairguide.autozone.com/znet...5280072a4f.gif
See if you have power coming out of the lightblue that is hooked to the flasher unit. If you don't, see if you have power on the white/red going to the flasher unit.
Old Jun 2, 2009 | 05:02 PM
1993 E-150's Avatar
1993 E-150
ok i have power coming from the light blue and red white wire,
Old Jun 2, 2009 | 10:05 PM
Franklin2's Avatar
Franklin2
I would mess around with the turnsignal switch(Ford calls it a multi-function switch. Once you take the steering wheel off to take a look at it, make sure the wiring plugs are inserted all the way.
