E40d Intermittent Leak
Old Apr 29, 2002 | 04:07 PM
kenyk's Avatar
kenyk
I have E40D out of 92 Ford E250. After a hard long drive the transmission leaks when the engine does to idel. As long as I am driving it is fine. When I stop it will leak a pint easily. The leask is coming from the drain plug in the bell housing. It almost seems that there is a pressure build up that is forcing fluid past the seal, when yo are driving the pressure is dissipated in the transmission. When the engine cools down the leak stops.
Old Apr 29, 2002 | 04:43 PM
Ratsmoker's Avatar
Ratsmoker
One question. How do you know that it isn't leaking while you are going down the road?? I suspect it would be the input shaft seal.
Old Apr 30, 2002 | 06:12 AM
dsc's Avatar
dsc
