t5 swap??
Old Jun 1, 2009 | 01:18 PM
1978300ford's Avatar
1978300ford
Question t5 swap??
Is it possible to put a t5 from a mustang in the trucks??
Old Jun 1, 2009 | 03:29 PM
johnboy427's Avatar
johnboy427
Yeah, but it wouldn't be that easy. You will need to find the correct bellhousing, and most likely move the crossmember and get a longer drive shaft. The T-5 clutch fork was backwards from the our trucks, it used a cable that pulled forward against a pivot at the front of the bell housing, our trucks use a fork that that pushes to the rear with the pivot at the rear of bellhousing. There are adapters for using the T-5 on an early car bellhosing which could probably be adapted to work in a truck. I am sure it could be done but it will be a custom job.
-Johnboy
