engine light missing
Old Jun 1, 2009 | 07:49 AM
bigrig62's Avatar
bigrig62
i gonna play stump the forum here. I changed the cps to a black one no change,ran buzz test injectors sound ok and cylinder contribution test no codes what else could be making 7.3 run witha miss
Old Jun 1, 2009 | 07:51 AM
riverrat41's Avatar
riverrat41
Maybe the UVCH plug in that plugs into the valve cover gasket could be chaffed or not plugged in all the way.You may need the .50 fix.I do not have the pictures but one of the gurus will chime in shortly.Hope you get it going!
