Sponsored by: Real Truck
2008 5.4 egr?
Old Jun 1, 2009 | 12:42 AM
bayou barataria's Avatar
bayou barataria
2008 5.4 egr?
Hey guys I have an 2008 250 with a 5.4 and am wondering if it has an egr sytem for the motor. I notice that the oil stays pretty clean longer than my other cars and truck that I have. I'm thinking maybe no egr?
Old Jun 1, 2009 | 07:10 AM
Johnny Langton's Avatar
Johnny Langton
There is no "EGR" system on the 3V 5.4L. The PCM creates it's own internal "EGR" via cam timing manipulation during cruising and low load operation.
JL
Old Jun 1, 2009 | 09:04 PM
bayou barataria
So it does pump exhaust back into the engine? Where is the valve and can it be disabled?
Old Jun 2, 2009 | 07:02 AM
Johnny Langton
There is NO valve. It's simply retarding the camshaft so exhaust evacuation isn't as efficient and a percentage of the exhaust stays in the chamber. Disabling that function will be detrimental to fuel mileage and increase emissions.
JL
Old Jun 2, 2009 | 09:11 PM
bayou barataria
Well it must not be much, the oil stays clean for a long time, they should have done that long ago. In my opinion it is just stupid to pump exaust back into the engine, there has to be a better way to reduce emissions.
Old Jun 2, 2009 | 11:01 PM
Johnny Langton
You increase fuel economy with EGR,and it has little or nothing to do with how quick the oil gets dirty.
JL
Old Jun 3, 2009 | 08:48 PM
bayou barataria
I would have to respectfully disagree with you, you introduce exhaust back into the engine and the oil gets very dirty from the carbon. On one of my molder engines I just had the motor rebuilt and the oil was getting dirty quickly. Turns out the egr opening on the manifold had the wrong gasket and had stuck the valve open from the carbon. I don't see how that could increase mileage either but I am not an engineer and could be wrong. Thanks for the info though.
Old Jun 4, 2009 | 06:49 AM
Johnny Langton
Disagree all you want-I have the EGR flow approx 60% higher than stock out on my work truck, and it has no affect at all on how quick the oil gets dirty. Same on my Tbird, Navigator, etc, etc, etc.
It increases mileage by decreasing the engine's efficiency and forcing you to use more throttle to maintain the same speed. This eliminates some of the pumping loss of the engine.
JL
Old Jun 4, 2009 | 10:09 AM
Ballswedge's Avatar
Ballswedge
JL
I have to disagree. I have a '99 with egr. I installed headers that have no egr bung therefore, have removed the egr plumbing until I can find a place that will bend me some small pipe. My tuner has allowed me to turn egr switching off and I have noticed no change in mileage. It even passed emissions last year with no change in PPM of any emitted exhaust gas in comparison to the prior year with EGR. It may have a marginal fuel economy effect on smaller cars/engines but when it comes to my V10, there is no difference. I don't know how this would effect a 5.4 at all.
I agree about it not having an effect on oil. Although, you are re-using dirty exhaust, it could increase the amount of carbon in the oil if the vehicle is consistently driven under light or no-load. This is just my thought on the subject.....
Old Jun 4, 2009 | 10:27 AM
Johnny Langton
If there was a reliable way to add EGR to my '05-I would based strictly on past experience with fuel economy improvements using EGR flow to decrease pumping loss at low load. If you eliminate EGR, you hurt economy-unless the system was not functioning properly to begin with.
JL
Old Jun 4, 2009 | 01:46 PM
Ballswedge's Avatar
Ballswedge
JL
It was functioning properly as I did not receive any "low egr flow" or "egr system failure" codes when the system was installed. The valve is clean and free of carbon build up as is the passage in the intake. Anyhow, I'm reinstalling the tube as I like everything to be functional as installed from the factory. As for it increasing my mileage, that's very doubtful. We'll see if it stayed the same due to the headers when I put it back on.
Old Mar 30, 2024 | 10:48 AM
dvestes's Avatar
dvestes
1st Gear
There is a device on the 5.4 called the EGR module. Can anyone expound on that?
GN1220
Apr 3, 2022 11:59 AM
bubahyde
20
Mar 19, 2017 04:02 PM
jasonhaysler
Modular V8 (4.6L, 5.4L)
Jun 27, 2015 12:33 PM
mx250racer1
6.4L Power Stroke Diesel
Feb 16, 2014 07:51 PM
wall77
Nov 12, 2009 07:36 AM
