Tailgate Assembly (washers)
Old May 31, 2009 | 05:38 PM
GeneT's Avatar
GeneT
When I purchased my 72 Camper Special 390 it came with the tailgate and parts for installation but it was not installed on the truck. Most of the install I understand but a part that I haven't figured out is where the four large non metalic washers should go.
As a seperate question, just an after thought and I haven't searched the forum for this yet, is does anyone have a reasonable priced source for a drop in bed liner? I just wire brushed out the bed and painted it with brown Hamerite to slow down the rust. The color looks good and I'd like to protect it without spending too much money.
Thanks, Gene
Old May 31, 2009 | 08:44 PM
GeneT's Avatar
GeneT
Figure the washers out
After finding a stand to set the tail gate on so I could get all the pieces lined up with the gate in the swung open position the only place that made any sense was where the hinge attaches to the truck body.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
The tail gate is functional but it looks like Ford engineers embraced the concept of having a little wiggle room in the system. I have to manually center the tail gate when I close it to avoid banging the tailgate into the receptacle on the body.<o></o>
<o></o>
Next up is the heater core and hoses.<o></o>
Old Jun 1, 2009 | 02:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by GeneT
After finding a stand to set the tail gate on so I could get all the pieces lined up with the gate in the swung open position the only place that made any sense was where the hinge attaches to the truck body.fficeffice" /><O></O>
<O></O>
The tail gate is functional but it looks like Ford engineers embraced the concept of having a little wiggle room in the system. I have to manually center the tail gate when I close it to avoid banging the tailgate into the receptacle on the body.<O></O>
<O></O>
Next up is the heater core and hoses.<O></O>
Welcome to FTE
According to the tailgate hardware illustration in the 64/72 Ford Truck Parts Catalog, there are four bolts with integral washers used to attach the hinges to the body, two per side.
4) 372421S39 .. Bolt & Washer Assy-Hex Head / 3/8" -24 x 1"
I see no other washers anywhere.
All the hardware (hinges, scissored brackets, latches, rubber bumpers, etc.) is the same: 1964/66 F100/250 2WD Styleside, 1967/72 F100/350 Styleside.
While the styling of the 1964/66 vs 1967/72 tailgate is slighty different, both fit 1964/72's.
In 1967, Ford originally had two plastic bushings used as combo anti-rattlers/spacers. One on either side of the tailgate where the hinge cups fit into.
In 1968 Ford obsoleted the spacers, the parts catalog says "improvise from foam rubber."
I was at a Ralph's supermarket t'other day, saw a swimming pool kids play toy, prolly used to "bop" kids over the head with.
It's a 5 foot long piece of round foam rubber with a hole thru the center.
I'll betcha you could get one a these, cut off a coupla inches and use them on the tailgate.
Old Jun 7, 2009 | 03:47 PM
GeneT's Avatar
GeneT
Bill thanks for the information!
guessrow
2004 - 2008 F150
23
May 7, 2022 05:01 PM
1999er
Jul 24, 2014 05:27 PM
timmygyu
1978 - 1996 Big Bronco
Jun 13, 2012 03:07 PM
JohnT
Aftermarket Products
Aug 28, 2008 06:10 PM
jlande
Mar 7, 2004 11:28 AM
