Sponsored by: Real Truck
check engine light is on
Old May 31, 2009 | 12:10 PM
TWALL_NJ's Avatar
TWALL_NJ
ok i got into my 01 250sd yesterday and noticed the check engine light is on, is there way i can check the codes befor i bring it to m y mechanic.. i know you use to be albe to use a paper clip and stick it in the 2 ports under the dash on my older car witch was not a ford, does anyone know if u can do that with my truck.... and if i can can someone give me some guidance on how to do it in this truck
thanks guys
Old May 31, 2009 | 12:22 PM
87 F-150 I6's Avatar
87 F-150 I6
What engine do you have? If its a gasser, you should be able to take it to a local parts store like Advance, checkers, or O'Reillys and have them scan it. If its a diesel, they don't have the right scan tool to get the ford power train codes that diesels have. If you had a program like Autoenginuity with the ford pack you could scan it your self. Is the truck doing something specifically that would trip the check engine light?
Old May 31, 2009 | 12:27 PM
TWALL_NJ's Avatar
TWALL_NJ
sorry its a 5.4l gasser well it just came on yesterday but i have noticed over the last week or so its sluggish off the line, it doesent have the pep it use to have and when i start in the morning its hesitant at first but always starts up
Old May 31, 2009 | 12:29 PM
TWALL_NJ's Avatar
TWALL_NJ
does advance auto charge to scan it do you know?
Old May 31, 2009 | 12:33 PM
projectSHO89's Avatar
projectSHO89
No. They do it so they can sell you parts. Same with AutoZone (except California).
Write down the fault code(s) - Pxxxx where xxxx is a four digit code.
Tell them you're going to "check it out".
Leave.
Come back here and plug the fault codes into the SEARCH feature. There are common ones that get asked every week.
If you can't find a relevant post or description, ask (post the codes you have).
Old May 31, 2009 | 12:34 PM
87 F-150 I6
Leave.
yep, what he said
Old May 31, 2009 | 12:39 PM
TWALL_NJ's Avatar
TWALL_NJ
alright guys thanks, in gonna run down there now and have it scanned.... i will keep you posted i might need more help... thanks again
Old May 31, 2009 | 02:16 PM
TWALL_NJ's Avatar
TWALL_NJ
ok advanced auto scanned it for me and came up with the code p0720 output speed sensor circuit malfunction.... now is that the sensor on the top rear of the tranny if so is it hard to change and how costly might it be.. hope you guys can help me
thanks!!!!!
Old Jun 1, 2009 | 06:17 AM
projectSHO89
thanks!!!!!
You skipped a step.
