Problem!!!
Old May 31, 2009 | 07:45 AM
ilo9's Avatar
ilo9
Problem!!!
Fellas,
got in the truck this morning to go get bagels and the paper. started the truck stepped on the brake and the shifter wouldnt go into Drive. released the pedal and tried again and nothing. two or three times more and it finally moved. What can that be???
Old May 31, 2009 | 10:40 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Physical barrier......check the linkage. Or an intermittant wire at the BOO switch. If the computer doesn't know that you have your foot on the brake, it won't shift.
Old Jun 14, 2009 | 07:05 PM
DFord023's Avatar
DFord023
Does anybody know where I can get a parts breakdown for the linkage?
Old Jun 14, 2009 | 08:07 PM
DSMMH's Avatar
DSMMH
Originally Posted by ilo9
Fellas,
Did you check your brake lights to see if they are working. I believe the PCM needs a signal from the brake switch to indicate you have the brake applied. Could be an intermittent brake light switch.
DSMMH
Old Jun 14, 2009 | 08:52 PM
FlyCanadianGuy's Avatar
FlyCanadianGuy
Fellas,
The truck was OBVIOUSLY unhappy that you were using it to get bagels and a paper. Hook up a heavy holiday trailer to it, and throw some fishing tackle in the back, and that truck will work like a charm every time.. :P Good luck with the diagnose, and please do keep us informed!
Old Jun 14, 2009 | 09:03 PM
DFord023's Avatar
DFord023
Brake lights are workin fine. I had to dismantell the steering colum in the Lowes parking lot and manually assist the mechanism to allow it to shift. Made for fun times while my truck was taking off with me laying on my back in the floor.
Old Jun 15, 2009 | 11:13 AM
natem8301's Avatar
natem8301
Fellas,
Were you parked on a steep incline or decline?
Old Jun 15, 2009 | 12:34 PM
ingman's Avatar
ingman
flycanadianguy, thats great. So our trucks are easily embarrassed? i will rememder that.
