Brownie Gearbox?
Old Jan 11, 2004 | 11:52 AM
Ogrebonz's Avatar
Ogrebonz
I'm also looking for info on the Brown Lipe and Spicer Aux transmissions. Looks like this thread has died though. Email me at (without spaces) ogresemail @ chartermi.net is you have any information on this subject. Thanks, Ogre.
Old Mar 7, 2004 | 03:17 PM
Loadstar1700's Avatar
Loadstar1700
Brown Lipe Aux Trans
Hoping to get ahold of Brown Lipe Bob as well.
"I could talk about these Brown-lipes for ever as I have been researching these things for years and have quite a collection of them. I hope this info is of some help to you. If you like, You can reach me at (Click Here...).
Brown Lipe Bob "
That's the guy I need! Or any of you fine folks or Ogres who know about these boxes.
Please forward contact info.
Many Thanks
Robert Kennett
Old Aug 16, 2006 | 09:55 PM
bigbusguy's Avatar
bigbusguy
Question
The never ending topic.
I also have Brown lipe gear model 47n1 and looking for more info and parts like the yokes.
Brian
North
Idaho
bigbusguy@yahoo.com
Old Aug 17, 2006 | 06:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
... Welcome to Ford Truck Enthusiasts!
This happens to be an old thread, however stick around and someone will be by to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 17, 2006 | 07:43 AM
Ogrebonz's Avatar
Ogrebonz
Unfortunately I don't have the links anymore, but several companies still stock parts and even remanufactured Brown-Lipe gearboxes. If you Google for heavy truck transmission rebuilders or something similar you'll find something. I even got some price quotes emailed back to me. Sorry I threw it all out, you never know what'll be useful... Ogre.
Old Mar 2, 2007 | 01:48 PM
acheda's Avatar
acheda
I know this is an old thread, but I like brownies and am willing to share.
For some Brownie pictures, including a nifty cross-section, please see my gallery by clicking on my username above.
Old Oct 28, 2007 | 11:47 AM
flapperhead's Avatar
flapperhead
47 aux
the 47 type trannies from what ive found are under geared such as 1.5-1 ,1.2-1 and 1-1.. no overdrive in them ... mike
Old Oct 31, 2007 | 08:54 PM
rbaker6336's Avatar
rbaker6336
they made these both ways with 3rd being direct or overdrive
Old May 20, 2008 | 10:01 PM
chuck78757's Avatar
chuck78757
The brown lipe that you have is an auxiliary transmission. In a 4x4 application it would have to install between the main transmission and the transfer case. This is only possible if you have a separate transfer case form you transmission. you will have to remove your transfer case and move it further to the rear and install the brown lipe then reinstall the transfer case with a shorter drive shaft to the rear and a longer to the front. this is a lot of work. ALSO... The brown lipe is a low gear and a direct gear ONLY. Installing this would only gain you a lower gear and not give you an overdrive. I have dealt with alot of brown lipes andI have yet to see one that was not 0.81 and 1.00 in a two speed.
Old May 21, 2008 | 12:19 AM
rbaker6336's Avatar
rbaker6336
here are some facts on Brown & Lipe/Spicer
Spicer 5831
Old May 21, 2008 | 05:22 AM
acheda's Avatar
acheda
Spicer 5387
There is more information in a newer thread:
https://www.ford-trucks.com/forums/5...ie-thread.html
There is plenty of room for confusion because of the long history of auxiliary transmissions. Brown Lipe is an old company that was purchased by Spicer at some point in time that is unknown to me. I believe Spicer operated Brown Lipe as a division, still using the Brown Lipe name.
My Father's Brownie was the two-speed that chuck78757 is describing. It was a small auxiliary transmission -- probably the only one that really was sized to a half-ton pickup. It was specifically designed to be mounted either way and hence could be used as either an overdrive or as an underdrive -- my Dad used it as an overdrive behind a straight 3-speed and then later as an underdrive behind a 3-speed/OD.
Old Aug 3, 2008 | 02:32 AM
67Cowboy's Avatar
67Cowboy
Unhappy Hard to get information
I've been restoring pickup trucks for a few years now, I'm semi retired and was once a Parts man for a major parts distributor. I've learned the hard way since leaving to company that certain people don't really want you to find out that you can get 0.63 to 1 ratio or 0.73 or 0.81 or 0.87 to 1 ratio because 0.63 would get you at least 27% better fuel milage.
_ It's kinda like those 7,000 patents for devices that get over 100 mpg that now belong to big oil companies instead of the old boy who built it on his work bench after sacrificing 1,000s of hours of his life to try and help mankind. But instead big oil bought it out, some times with threats and force so they could control the patent and hide it away and charge you $5.00 or $10.00 a gallon !
_ There is a box called a Ranger 2spd over: Gear Venders has one that does under and over drive, you can get a kit to build a two under and 1 over out of the gear portion of an old NP203 Transfer case from a 4X4.
The Watson, Browny, Spicer, Atlas, New Process, are out there but you have to get on a web site like Street Cruzin or My Old Truck or 6066 GMC Guy to be able to talk to folks. I have a lot of info if you find me.
Old Aug 3, 2008 | 04:03 PM
  #28
magusjinx's Avatar
magusjinx
And then there is the story of the guy that installed a 2-speed rearend in his 4x4 ... He kept wondering why it dug the front end in the sand in four-wheel ...
True story ... Happened in 29 Palms Cali ... 1975 ... He had a rack in the next quanset hut ...
Old Feb 28, 2010 | 07:38 PM
  #29
papecat's Avatar
papecat
I need help identifying my brownie as well...
Any ideas? No data plate or manufacturer names anywhere, just the stamped numbers you see in the pic.
Old Jul 23, 2010 | 06:13 PM
  #30
ford390gashog's Avatar
ford390gashog
I know this thread is old but for future reference the above unit is not a brown lipe. I went down this road as well. What you have is really a 2 speed underdrive watson trans.
