F100 lug pattern.
Old May 31, 2009 | 05:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by fordtruckman80
So basically,aside from the truck being lighter,I can pretty much call my truck an F150.
It's your truck...you can call it anything you want to, but...
If you have 4.50" bolt pattern wheels, do not tell the parts guy at some autoparts store you have an F150, because...
Not only are the wheels different, but so are the front brake pads, calipers, rotors, dust shields and related parts.
The rear brakes, drums and ALL corresponding internal parts are different (10" vs 11").
The front and rear springs are different, so are the shocks.
The frame is not the same, either.
Old May 31, 2009 | 06:26 PM
Fordzilla80's Avatar
Fordzilla80
Originally Posted by 81-F-150-Explorer
Correct.
some, but not all F-100s use the same identicle parts as the F-150. As far as GVWRs are concerned there is only 100Lbs difference between the Largest F-100 (5150) and the lightest F-150 (5250).
Longbed F-100s are more rare, as is shortbed F-150s in this time frame, 1980-1983, but both are out there, so to speak.
Thanks for the Info.I just looked,and I have the largest F100(5150).And also,I read somewhere that F100's have 4 rear leafs,while F150's have 5.
Old May 31, 2009 | 06:31 PM
Fordzilla80
Okay this is one of the biggest things i've always wondered about.What should I tell the parts guy?I need to replace almost all of the suspension and braking systems(Only because I want this truck bulletproof).I have the 5 on 5-1/2 bolt pattern,as well as HD Power Brakes.So i'm assuming I should tell him I have an F150,but i'm not sure.Whenever I make a trip to the Auto parts store,should I bring the old part in with me to make sure I get the correct new part?Cause I highly doubt any of the quacks at my local parts store know there's a difference in the bolt patterns and brake sizes in my F100 from the 5 on 4-1/2 F100's....Thanks for all the help ya'll.
Old May 31, 2009 | 09:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Okay this is one of the biggest things i've always wondered about.What should I tell the parts guy?I need to replace almost all of the suspension and braking systems(Only because I want this truck bulletproof).I have the 5 on 5-1/2 bolt pattern,as well as HD Power Brakes.So i'm assuming I should tell him I have an F150,but i'm not sure.Whenever I make a trip to the Auto parts store,should I bring the old part in with me to make sure I get the correct new part? Cause I highly doubt any of the quacks at my local parts store know there's a difference in the bolt patterns and brake sizes in my F100 from the 5 on 4-1/2 F100's....Thanks for all the help ya'll.
Nope It's better to tell them you have a F-100 with 11" brakes.
The secret is to tell them 11" brakes.
The F-150 does share brakes with your paticular F-100 though.
Why I said Some but not all F-100s share Identicle parts with the F-150.
Old May 31, 2009 | 09:35 PM
Fordzilla80
Okay will do.Hopefully they understand......
Thanks for all the help.
Old Jun 1, 2009 | 01:19 AM
LCAM-01XA's Avatar
LCAM-01XA
Originally Posted by Greyf100
all of the ford wheels carry a 4" backspacing which is the same as your trucks steel wheels, the jeep wheels have 5.25-5.5" backspacing
Uhm, no - that may be true with the Mustang and Mark VII, but not with the fullsize cars (Ford Crown Victoria, Mercury Grand Marquis, and Lincoln Town Car). Additionally said fullsize cars had a factory towing package option, one of the features of which are 11" rear drums. So while Mustang wheels may not be a direct bolt-on without the proper (1" to 1.5" thick) spacer, the fullsize cars wheels may just work out fine.
moyer h
Jul 23, 2011 08:39 AM
Comanche1Star
Oct 5, 2010 01:11 PM
l67cooled
Nov 12, 2009 08:51 AM
jeff1975
15
Sep 22, 2009 12:40 PM
69machscj
Jul 21, 2004 06:14 PM
