starter info
Old May 30, 2009 | 09:30 PM
txracer's Avatar
txracer
starter info
My truck has been starting hard lately, of course first I checked batteries.
Actually repaced under warranty (intertate). Then i pulled satrter and had Autozone check it out. They said it was Fine! RIGHT.
anyway i thought it might be over my head so i took the truck to a local (Houston) guru to diagnose the problem. He called me later and said it was the starter! said it was pulling 700 amps.
he gave me a quote for a stock starter(700) and a Gear reduction starter (796).. he told me they basically install an adapter plate and install this starter. I had never heard of this before. anyway I had to tow the truck home. Got online and found a great company that had the starter and adapter plate. starter 129 adapter 39. $12 shipping. received within 3 days.
Installed starter today
all I can say is WOW what a difference. engine might turn over 1.5 times and it is started. It actually scared me when i turned it over for the first time.
putting in a starter. check this out
Ford Products from Diesel Care!
excellent service from this company
txracer
Old May 30, 2009 | 10:49 PM
kawa's Avatar
kawa
I was not aware that an Adapter Plate" was required when replacing the "Stock" starter with a "Hi Torque" starter. Has anyone else had to use an adapter plate when changing?
Rog
Old May 30, 2009 | 11:55 PM
pjwoolw's Avatar
pjwoolw
Not sure about that vendor. Of course adapter plates for starters are pretty common. But I don't recall ever seeing one for these rigs. I do like the $200 CPS....... HMMMMM...... Don't think they move allot of those. But if the starter works well it's a good thing.
TX, did that thing come with instructions? If so maybe you could scan it and post it. Be interesting to see.
Old Jun 1, 2009 | 10:22 PM
txracer's Avatar
txracer
starter
no instructions. The adapter is about 5/8" thick. You will need to get longer bolts. Wiring is the same also.
turns the truck over SOOOOOOOO easy.
i would recommend this swap to anyone. I'm very happy. The company also answered any questions i threw at them. Very good customer service.
txracer
Old Jun 1, 2009 | 10:43 PM
kawa's Avatar
kawa
TracerX
Does this starter resemble the starter that you installed?
(That is if the link opens)
Rog
Ford 7.3 Diesel Starter Powerstroke Truck HT 1995-2003 SND0355 17802: SND0355 / 17802 DB Electrical Starter-Alternator
Old Jun 1, 2009 | 11:46 PM
95_Dually's Avatar
95_Dually
If that is the starter, it is a lot smaller than the stock one. I replaced mine about 4 years ago and it is huge.
Old Jun 2, 2009 | 05:38 PM
FARM69's Avatar
FARM69
That's pretty cheap. I think a paid right at $200 for a new one when I replaced mine last year.
I've heard of the high torque ones, but never a adaptor for the PSD.
