checkin trans fluid
Old May 30, 2009 | 02:06 PM
dakoda60's Avatar
dakoda60
checkin trans fluid
ok ive got a 87 f150 n i believe its time to check the trans fluid. well ive heard that there is many different ways that it can be checked, well i was wonderin what the best and more proper n accurate way to check it would be...thanks for any advice
Old May 30, 2009 | 02:15 PM
fordpower46's Avatar
fordpower46
the most pressing question here is...
What trans does the truck have?
Old May 30, 2009 | 02:29 PM
pc_2000's Avatar
pc_2000
All the manuals I've read state running the truck to operating temperature, then with the transmission in park, on level surface, with motor running check the level on the dipstick. Should be in the hatched area or between the 2 holes.
Old May 30, 2009 | 03:18 PM
nflfreak43's Avatar
nflfreak43
make sure you atleast drove enough to get the TRANNY warmed up. that lets the fluids get going in the tranny. then doo as pc 2000 said as well.
Old May 30, 2009 | 10:54 PM
jr32560's Avatar
jr32560
knowing which trans ya had would help-if it's an auto -the above recommendation sounds right
