4 speed vs 5 speed?
Old May 1, 2002 | 05:46 AM
fiend's Avatar
fiend
4 speed vs 5 speed?
Well I am looking at trucks, and all the ones in decent shape have manul transmissions.
So it's time for me to learn to drive a stickshift. What's the difference between 4 and 5 speed?
Any advice on learning manual?
Old May 1, 2002 | 07:59 AM
sauerf100s's Avatar
sauerf100s
4 speed vs 5 speed?
Most 4 speeds aren't overdrive in high gear, and most 5 speeds are. Overdrive means the transmission is geared to turn the driveshaft faster then what the engine is turning. This saves bigtime on gas. With most non-overdrive transmissions, the driveshaft is turning the SAME speed as the engine.
Old May 2, 2002 | 04:45 PM
jopey's Avatar
jopey
4 speed vs 5 speed?
ford did use some 4spd trannys where 4th was over drive, and 1st was geared so high it was worthless if you are going to tow.
Old May 9, 2002 | 06:51 PM
90Bronc's Avatar
90Bronc
4 speed vs 5 speed?
If you have a choice go for a five speed. If you want a transmission that can tow or has a low first gear for fourwheeling look for a five speed with a "granny low" or "compound low". That way you have a low first and an overdrive.
Old May 12, 2002 | 01:52 AM
mikemc's Avatar
mikemc
4 speed vs 5 speed?
There aren't too many 4 speeds around still in late model vehicles. Most are 5 speeds and 5th is usually an overdrive. 5 speed is better if you have a choice. I have always owned manuals since my first car and after 18 years I still prefer them. My advice: find a large empty parking lot or other empty area and practice starting and changing gears until you are very comfortable. Remember to NEVER: 1) leave your foot on the clutch pedal between shifts and 2)hold the vehicle on a hill using the clutch. These two things will wear out your clutch way early.
Old May 13, 2002 | 08:50 AM
ringkong's Avatar
ringkong
4 speed vs 5 speed?
I have a T18 4SPD in my 88 F150 4x4.
I love it.. you can't break the damn thing. and GRANNY LOW to boot.
Although 65 is my top speed.. I have 4.10 gears..
Old May 13, 2002 | 10:39 AM
Kuntryboy's Avatar
Kuntryboy
4 speed vs 5 speed?
StrayKatJJL
Feb 27, 2017 08:28 PM
GunWerkz
New Member Introductions
Feb 1, 2017 04:51 PM
lonebeagle
Jun 22, 2016 12:44 PM
Ford31
1997 - 2003 F150
Apr 1, 2016 02:14 AM
Matt 68 F100
Sep 22, 2015 05:50 AM
