synthetic oil ?
Old Jun 2, 2009 | 05:51 PM
magnet1's Avatar
magnet1
Not only will it go longer between changes, but in the end it is cheaper. Also Amsoil is the only oil that does not use a parafen wax base to their oils which no matter how often you change it will eventually cause some kind of buildup in your motor. Theirs will run clean for as long as you run it. Even Mobil 1 doesent use the same base in their oils.
