Question about reverse eye springs
Old May 29, 2009 | 03:22 PM
mikes56's Avatar
mikes56
I just bought a set of reverse eye rear springs for my 56. it is the complete spring pack not just the main. My question is, the reverse eye springs are about one inch longer when installed with no load on them. they also appear to have less arch in them then the stock ones (hense the drop i suppose). They bolt up fine but they clock the shackle at about one oclock as opposed to the stock ones which clock at about 3 oclock. Would the stock ones rotate to about one oclock with some load on them???? is the additional inch in length with no load applied, preload??? Does it simulate the length that the stock springs would be when they had a load on them. I know the rear springs for 53-54 are 4 inches shorter than 55-56. this isnt the case these are a bit longer than the stock ones. i was wondering if any one else has ever experienced this. Thanks Mike
Old May 29, 2009 | 07:26 PM
MMB's Avatar
MMB
The fact that they are longer and flatter than the stockers means they could be de-arched to create even more drop. Just looked at both my 54 and 56 (stockers) and the shackles are both sitting at the 1 o'clock position so sounds like you should be alright.
Old May 29, 2009 | 08:46 PM
mikes56's Avatar
mikes56
great thank you for checkin
