C6 Overdrive
Old May 18, 2002 | 11:26 PM
jdawg78's Avatar
jdawg78
C6 Overdrive
Ok here's the deal. I have a 78 Ford F-250 4x4 with a 400 and a C6 auto. I am in a pursuit of better gas mileage and it seems like an overdrive is the way to do it. I was planning on shoehorning an AOD into the truck but the C6 is a much stronger tranny. However, the AOD's .67:1 OD Ratio is very appealing to me. The performance rebuilt AODs from FB, Jet, Art Carr, etc... all seem to cost around 2500-3000 with all necessary equipment. And rebuilding an AOD to stand up to a truck and putting it in will cost about the same. I would rather keep the stronger C6 in the vehicle an add an OD to that. I have looked at the gear vendors but the OD ratio isn't low enuf (.78). Have you seen any kits that would go to my truck and give me at least a 30% (.70) od reduction. I will put an AOD in if I have no other choice but the C6 is legendary. Any help woul be greatly appreciated. Thanks
Old May 19, 2002 | 11:51 PM
kwebb's Avatar
kwebb
C6 Overdrive
Go to http://www.gearvendors.com you can get an overdrive that goes on behind the transfer case. However, it's going to run you $2400 or so.
Old May 20, 2002 | 12:00 AM
AZ4x4f150's Avatar
AZ4x4f150
C6 Overdrive
