Does this sound resonable?
Old May 28, 2009 | 10:52 AM
rcn's Avatar
rcn
Is it a good idea on my '95 F150 2wd to put on an add-a-leaf on the rear springs and replace the old front springs with "heavy duty" ones?
I want to keep the original rake, but lift it without a lift kit.
Is this a good idea and inexpensive?
I plan to install 245 80 R15 tires soon too.
Thank you,
Rob
Old May 29, 2009 | 10:57 AM
alxsnmr's Avatar
alxsnmr
Somewhat reasonable. You will need to have an add-a-leaf that is the same width as your spring pack in your F-150. If I am not mistaken, the 2wd F150 has a narrower spring width than the 4wd F-150.
Old May 31, 2009 | 12:43 AM
TexasGuy001's Avatar
TexasGuy001
Its a 2.5 inch spring.
Old May 31, 2009 | 01:19 PM
Tom92F150's Avatar
Tom92F150
Rear add-a-leafs and leveling coils up front ought to give you the look you're after. In combination, they'll raise your truck about 1-2" depending on how much your old springs are sagging. You will, however, need to realign your front end after installing the taller coils. The toe-in isn't a big deal, but you (or the alignment shop) will have to replace the eccentric upper balljoint bushings to restore your camber.
