Bronco II Ford Bronco II
Sputtering at 55-65 mph
Old May 27, 2009 | 06:45 AM
whyjay's Avatar
whyjay
I'm borrowing my dad's ride. It's a 1990 bronco II. He told me it sputters at about 55-65 MPH & he wasn't kidding. It's like the motor quits for a split second. Any ideas what would cause this? I'd like to fix it for him in return for him loaning it to me. Thanks.
Old May 27, 2009 | 04:53 PM
Beechkid's Avatar
Beechkid
Well, could be fuel filter, clogged air filter, charging system issue, bad plugs/wires....
Old May 27, 2009 | 05:00 PM
whyjay's Avatar
whyjay
Yeah, Well I'm sure it could be any of those but it's in very good shape for a 1990 & the old man is very particular about his rides so I think I could rule out several of those. I was just wondering if anyone has had this happen to them before & had it be something that you wouldn'd expect.
Old May 28, 2009 | 01:06 PM
1Aauto's Avatar
1Aauto
Former Vendor
I had it happen on my Mustang, and it ended up being a bad plug wire.As mentioned above,There simple places to start and could cause those symptoms.
I've had bad wires right out of the box before,it's very possible.
Hope this helps,
T
Old May 28, 2009 | 01:19 PM
whyjay's Avatar
whyjay
I'm not doubting your answer but why would it do it only between 55-65 mph?
Old May 30, 2009 | 05:21 PM
Tedybear's Avatar
Tedybear
It could need a decent tune up. I'd be more suspect of a bad TPS (Throttle Position Sensor) Normally this will kick up if the truck/car has a lot of cruse control miles on it. Dead spot in the TPS will make the computer get bad info, and can do a number on how well it drives.
If you're good with a multi-meter? TPS is very easy to test.
S-
Old Jun 15, 2009 | 07:50 AM
WildPferd's Avatar
WildPferd
I had a similar problem on mine, and it ended up being a bad fuel pump. Could always just have the fuel pressure tested and rule that out.
Old Jun 18, 2009 | 06:41 AM
kernel-panic's Avatar
kernel-panic
Is it a manual or automatic? If you only notice it at that speed range, I'm almost willing to bet you need to pull diagnostic codes and run a vacuum test. I'm almost willing to bet that if the catalytic converter has never been changed on it, and the truck has over 100K miles on it....
Outside of that, pull diagnostic codes, do a wiggle test on all the engine wiring harness connectors, check ALL of your ground connections.....
Paraglider
90
Mar 1, 2019 01:21 PM
vegas_f150
2004 - 2008 F150
Jun 21, 2015 09:24 PM
mark_5102
2004 - 2008 F150
Dec 22, 2014 05:41 PM
hinkle
Apr 22, 2014 01:29 PM
GA7.3
Feb 13, 2014 06:19 AM
