Engine Bearing Help
Old May 26, 2009 | 11:52 PM
OrangeJuice's Avatar
OrangeJuice
Cool Engine Bearing Help
Hello,
I am replacing the bearings in a 390 and have a question about the bearing set. Where do the large bearings with the flange on them go? On the front bearing area or in the middle bearing area of the block and main cap?
Also, I noticed the bearings on the block, the oil holes don't line up. They seem to cover about 1/4 edge of the hole on the two front of the center and the one rear of the center. I noticed the oil holes in the bearings are centered and the oil holes on the block are off center. Do I have the right year of bearings for this engine?
Thank You
Old May 27, 2009 | 07:44 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thrust-bearing main bearings are in the middle on the FE - 3rd main cap.
I think one of the oiling mods some people do is to open up that hole in the bearings.
But wait for others to reply, it's been a while since I rebuilt an FE
krewat's Avatar
krewat
Old May 27, 2009 | 08:54 AM
Freightrain's Avatar
Freightrain
Ya, the thrust goes in the center main.
Ya, the oil holes NEVER line up. For a stocker, that's fine(it made it 40 yrs already). For better oiling, match the holes up. Some do the bearings, some do the block. Some also say doing the block weakens the block/cap area. It also takes a good cleaning to get the metal shavings out(usually have cam bearings out). For simplicity, carefully take a dremel and dress the bearing oil hole til it matches the block. DO NOT NICK THE BEARING SURFACE!!!!!! Work it from the back side, go easy, take your time. Make sure to use some fine emery/crokus cloth to remove any burrs.
Old May 27, 2009 | 12:14 PM
Redmanbob's Avatar
Redmanbob
I do know the 65'(prior) block has a specific thrust bearing set that must be used. Not sure what year your is. Search "Oiling" for Mods info and there will be plenty reading.
Old May 27, 2009 | 01:52 PM
OrangeJuice
OK, so it's OK to open the oil holes a bit?
Thanks
Old May 27, 2009 | 02:35 PM
krewat's Avatar
krewat
Thanks
Yes, on the bearings. Follow Freightrain's advice
Old May 28, 2009 | 12:52 AM
OrangeJuice
OK everyone, I put a little relief in the bearing oil holes and they turned out good and smooth. I also installed the crankshaft and it spins freely. Tomorrow I will install the pistons and new rings.
Thank You everyone for your help.
OJ
Old May 28, 2009 | 01:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Redmanbob
I do know the 65' (prior) ** block has a specific thrust bearing set that must be used.
8) B8A6333A .. Numbers: 1-2-4-5 Main Bearings
2) B8A6337A .. Thrust Main Bearing (#3)
Fits: 1958/60 332/352.
8) C1AE6333A .. Numbers 1-2-4-5 Main Bearings
2) C1AE6337A .. Thrust Main Bearing (#3)
Fits: 1961/63 352/390/406/427.
8) C4TZ6333H .. Numbers 1-2-4-5 Main Bearings
Fits: 1964/76 352/360/390/410/428.
** 2) C4TZ6337H .. Thrust Bearing (#3)
Fits: 1964/65 352/390.
2) C6TZ6337J .. Thrust Bearing (#3)
Fits: 1966/76 352/360/390/410/428.
