timing chain flapping
Old May 26, 2009 | 08:56 PM
FORD E-150's Avatar
FORD E-150
92 ford 302 5.0
my timing chain is rattling i took the timing cover off there is no
timing chain damper or tensioner on hear is there supposed to be on this model
plus it has some play is that suppose to be like that it only has
78k miles on it
Old May 26, 2009 | 09:51 PM
Conanski's Avatar
Conanski
No tensioner on these motors, get a quality timing set like a Cloyes double roller and replace it while you have it all apart.
Old May 27, 2009 | 05:55 AM
FORD E-150's Avatar
FORD E-150
so it not suppose to lose
Old May 27, 2009 | 12:22 PM
IntheTrees's Avatar
IntheTrees
There should be 1/2" or less deflection.
Old May 28, 2009 | 03:15 AM
daddy172005's Avatar
daddy172005
In my opinion if you have doubts and already have it apart then the best thing to do would be to change it.
Old May 28, 2009 | 12:09 PM
Beanscoot's Avatar
Beanscoot
The silent chains become loose after a very short time, but continue to work for over 100,000 miles typically. Then they jump a tooth or two, resulting in terrible running but you can still limp home, with no damage.
