Tilt Hood needs a Latch
Old May 26, 2009 | 01:20 PM
medicpg's Avatar
medicpg
I am in the process of installing my new Tilt Hood kit and I want to install some kind of Latch with the cable running into the Cab for security.
Has anyone come up with an idea for this?
Old May 26, 2009 | 01:38 PM
jaye's Avatar
jaye
check mytbtruck he used one on his truck, I think it was from an S10
Old May 26, 2009 | 01:47 PM
medicpg's Avatar
medicpg
Thanks Jaye that wont work for me since on tilt hood I want it to latch closer to the cab
Old May 26, 2009 | 02:23 PM
Julies Cool F1's Avatar
Julies Cool F1
Your profile says your truck is a 91 F-150?
Can you give us a little more info? What kind of truck is this, is it a full front tilt with fenders or just the hood itself? What cinversion kit did you use, etc. etc?
Thanks
Old May 26, 2009 | 02:59 PM
medicpg's Avatar
medicpg
Hi Julies....wow. I guess I used my 91 Ranger stats, although I did have a 98 F150.
I updated my info. I have a 1954 F100. I just installed the Flip Kit for the hood from Mike Chesser
Old May 26, 2009 | 03:26 PM
sdetweil's Avatar
sdetweil
hm.. my 55 has a flip (reverse tilt) kit on it, and it uses the stock latch
I have been looking for a cable controlled latch to take its place..
this one from watson street works seems like it might work..
Latch and Catches
sam
Old May 26, 2009 | 03:39 PM
medicpg's Avatar
medicpg
That is a nice looking Latch setup. I wonder if something like that can be mounted close to the Cab since thats the part I want latched down...
Old May 26, 2009 | 03:42 PM
jaye's Avatar
jaye
I will have to do some serious thinking however, someone on this board did one that is mounted just forward of the cowl vent. He used a trunk lock from a car and welded it in.
Old May 26, 2009 | 03:45 PM
sdetweil's Avatar
sdetweil
they have another which is more like the trunk latch
Sam
Old May 26, 2009 | 03:51 PM
medicpg's Avatar
medicpg
that one is nice too and based on the orientation might work better. I hadnt thought of using a trunk latch...great idea !
Old May 26, 2009 | 04:27 PM
jim collins's Avatar
jim collins
About 20 years ago my brother made a tilt hood on hi 53 f100 and I believe he used a latch from a 58 ford sedan. I could find out next week when I see him. If interested E-mail me at :jimcollins@frontiernet.net:. jim
Old May 26, 2009 | 04:45 PM
AXracer's Avatar
AXracer
biggest issue is that with all the front opening hood kits I've seen, the hood slides back towards the cowl at the end of it's swing. most latches are designed for straight down movement.
Old May 26, 2009 | 04:48 PM
medicpg's Avatar
medicpg
great Point !! I forgot about that
Old May 26, 2009 | 05:06 PM
cmoritz's Avatar
cmoritz
So mount it horizontally, cut a vertical slot into your cowl, make an adjustable mount 'inside' the cowl and mount the catch horizontallyto it..mount the striker on the hood and your good to go...easier said than done right? LoL! just an idea..
Old May 26, 2009 | 05:09 PM
medicpg's Avatar
medicpg
another good idea...thanks Mertz...It actually does sound easy. My biggest fear is getting the latch working and forgetting to put the release mechanism inside the cab
