I'm in need of having some work done while I'm in Okinawa Japan. What I'd like is for someone to mount a 14 bolt, and a hp dana 60 under my ford, using a 9 in. suspension lift. I want to keep the coils under the front, and use some aftermarket wedges on the 60. So it would be providing the dana 60, mounting the 14 bolt, the dana 60, the 9 inch lift, hooking up the drive shafts and the brakes. Being broke just like everyone else in this economy my part of the offer would be giving whoever did it the 9" and dana 44 hp out of my truck, the dana 44hd out of the chevy I'm getting the 14 bolt from, any of the 351m/400 parts in the barn,which is a set of heads, two shortblocks that need rebuilds, a 4x4 c6 trans(supposed to be good but I dont know) two turbo 350's hooked to np 203's, and $1,000 cash. I'll pay for the lift, the wedges, and provide the 14 bolt, along with the driveshafts out of the 3/4 ton chevy to use to make the new shafts. Whoever would be willing to do it would have to provide the labor, including making the driveshafts, and hooking up the brakes, and the dana 60. Does this sound fair? Thanks guys, let me know.
alright where is your truck located at? and what time frame do you want this done in? i can't make the driveshafts and there isn't a local place for them but PST makes good shafts and arn't crazy expensive the one in my t-bird was $400 and it's good for 800hp slicks and a transbrake
Sorry can;t believe I left that info out. The truck is located in East Tenn. I could drop it off in most southern states on June 19th or 20th, the last couple days of my leave. As far as a time frame, anytime before Dec. 15th would be awesome. The shafts I can take care of, I don't need anything balanced, just some square tube driveshafts, it won't be seeing much road time, and nothing over a couple of miles at most.
