Lean bank 2
Old May 25, 2009 | 09:56 PM
hoyt1228's Avatar
hoyt1228
Lean bank 2
I have a 2000 exp with the 4.6. It is running rough and showing code for lean bank 2. Can someone give me an idea about what would cause this code. Ford dealer wold not help they just wanted me to pay to run diagnostics. I just cant afford that right now,but I would really like to have me truck runnig again. If you could help me it would be great. Thanks for looking.
Old May 26, 2009 | 07:26 AM
projectSHO89's Avatar
projectSHO89
You have a vacuum leak, probably.
Old May 26, 2009 | 10:53 PM
hoyt1228's Avatar
hoyt1228
I have checked all vacumm lines and I can not find a leak. Any other suggestions?
Old May 27, 2009 | 05:45 AM
projectSHO89
Keep looking. Leaks are not always a line.
Old May 27, 2009 | 12:39 PM
hoyt1228's Avatar
hoyt1228
I will look again. I will let you know what I find. Thanks
Old May 27, 2009 | 10:48 PM
hoyt1228's Avatar
hoyt1228
I took it into the shop today. They said that somehow I had antifreeze down around cyl 5 & 7. He cleaned them out and said that It was running better. Thanks for trying to help me out. Jamie
Old May 28, 2009 | 10:26 AM
alloro's Avatar
alloro
Check for leaks in the heater hoses that run above those cylinders.
Old May 28, 2009 | 08:43 PM
hoyt1228's Avatar
hoyt1228
It was a crack in the thermostate housing.Thanks for the suggestions. Jamie
Old May 31, 2009 | 08:40 AM
jimvw57's Avatar
jimvw57
I had the same error code, found I had left the oil filler cap off. (oops)
