302 in my 56 is leaking coolant from rear seal area? Help!
are you sure its not coming from the back of the intake at the coolant crossover.
has it been overheated? could be a head gasket.
but i'm thinking its a corroded freezeplug most likely,
just be carefull using stopleak products, they can plug the flow of collant to areas. just replace freeze plug.
make sure its not coming from the front of the motor, and just trailing down to the back. could be waterpump gasket.
Thanks for helping.. I did cheat and use Bars stop leak, I had to get to work, I need to fix it now... I saw no coolant anywhere except at the flat cover on the front of the auto trans. Is there a freeze plug on the back of the engine? Pull the C4? Is there room to tap in a std plug back there?
Thanks!
Thanks!
the one on the left is probably what you have installed, try to get one with more depth, it may even bottom out. its a very tough job with the motor in. and yes its between your motor and tranny. you do have others, you might want to check them while your at it, if memory serves correct they are under your exhaust manifold/above oil pan. good luck on this, i hate freeze plugs.
There are no freeze plugs on the back of a small block Ford, however there are freeze plugs on the front and back of each cylinder head and I suspect that is where your problem lies. It would be better to take it apart and do it right instead of trying to do it half-A$$ed cause it will likely just lead to more problems.
i know for sure the 351's have em in the back.
Yes, I'm sure as I just looked at the back of two SBF engines that I have (289 & 302) and there are no freeze plugs in the back of the block except for the two on the back of the cylinder heads. The 260 through 302 all share the same block configuration, now a 351W does share similar characteristics although it has an increased deck height making the stroke longer, however I don't know whether or not it has freeze plugs in the rear of the block as I haven't seen the back of one for several years and my memory isn't as good as it use to be!
