Window Issues
Old May 24, 2009 | 07:21 PM
shawnyboy's Avatar
shawnyboy
Window Issues
Hello to all. 1979 F150 4x4 passenger side window is hard to roll down or up. I've taken the door panel off, lubed any pivot points that I can see, but man is it hard to crank down. If I fuss with it, sometimes it hits a "sweet" spot and rolls a few inches before binding again. Are the registers bad? Thanks Shawnyboy!
Old May 24, 2009 | 10:32 PM
fmc400's Avatar
fmc400
MSEE
I had this same issue, and replacing the regulator solved the problem. You can buy the roll gear separately, but if the teeth on the window arm are worn as well, it's probably best to just buy the entire regulator assembly. Mine were $60 a piece, one for each door.
Your problem may or may not also be caused by the window felt being too tight, but in my experience that stuff dries and gets smaller with age, so it's more likely the regulator is causing the trouble.
Old May 25, 2009 | 12:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The following window regulators fit: 1973/79 F100/350 & 1978/79 Bronco
D8TZ1023200A .. Right Window Regulator / Obsolete
DON SANDERSON FORD in Glendale AZ has 16 = 623-842-8762
The last "list price" was $301.00 (!) but Sanderson has 1000's of obsolete parts, sells these for less than $80.00 each.
D8TZ1023201A .. Left Window Regulator / Obsolete
GREEN SALES COMPANY in Cincinnati OH has SIX: 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has TWO: 800-546-7278.
D6AZ5323240A .. Window Roller / Obsolete
Fits: 1975/79 F100/350 / 1978/79 Bronco / ALL 1973/79 Passenger Cars.
GREEN SALES has 22.
JST AUTOMOTIVE in Lebanon TN has 10 = 615-443-3086.
Most autoparts stores used to carry these rollers, because they fit so many applications.
Old Jun 3, 2009 | 02:47 PM
1Aauto's Avatar
1Aauto
Former Vendor
We have them for your application
Ford Window Regulators
Old Jun 3, 2009 | 03:43 PM
hp246's Avatar
hp246
I had a similar problem on 67 Fairlane. I sprayed brake cleaner thoroughly into the regulator, cleaning out the crud. Then sprayed white grease intot the regulator. Worked the regulator up and down gradually. Did not try to force the regulator, just let the white grease work its way down into the mechanism. it took quite a bit, but eventually was able to roll up and down no problem. That was 2 years ago, and haven't had the problem since. As a preventative measure, I sprayed withe grease into the other side and have not had a problemn with it.
Old Jun 3, 2009 | 08:11 PM
shawnyboy's Avatar
shawnyboy
Thanks for the tip. I'll try it and let you know how it works.
