Sponsored by: Kumho
Front Disc Removal
Old May 24, 2009 | 01:50 PM
Dustmaster's Avatar
Dustmaster
Front Disc Removal
I have a 2002, F350 Dually. I am in the process of putting new rotors and pads on the front end. I have removed the lug nuts, wheel, and extender bolts. I read a post in here that says if you have a 4 wheel drive dually, you need to remove the hub plate. What are the procedures for taking the hub plates off? Any assistance would be greatly appreciated. Thanks.
Old May 25, 2009 | 05:27 AM
Lazy K's Avatar
Lazy K
Never done one but if you look closely at it there should be eight bolts holding the hub plate, remove these and take it off. Torque these to about 130ft.lbs when refitting.
hope this helps.
