5.8/5.0 Computer Question?
Old May 24, 2009 | 02:01 AM
Killa-Kanaka's Avatar
Killa-Kanaka
Hi all,
I am new here but have been a long time ford man. I am in the middle of flipping cabs between a 93 & 94 F-150. I am not sure and hope you can help me. The 93 have the wireing and computer for a 5.8 (The 5.8 Motor needs to be rebuilt) so I can't use it. would this work with my 5.0?
My Truck
Thanks
All
Old May 24, 2009 | 02:08 AM
Killa-Kanaka
Hi all,
My Truck
Thanks
All
Old May 24, 2009 | 07:23 AM
Killa-Kanaka
Sorry I dont have edit capability (Dont know why). Motoerator please delete 2nd posting.
Thanks
Old May 24, 2009 | 09:09 AM
Conanski's Avatar
Conanski
The wiring is the same and the 5.8 computer will run the 5.0 but not perfectly, so why don't you swap in your 5.0 computer.
Old May 24, 2009 | 01:10 PM
garywh's Avatar
garywh
Hello Fellows,,can l put a computer from a 95 f150 into a 92 f150 (same moter 302) and what do l do to prepare it ?????
Old May 24, 2009 | 09:12 PM
Killa-Kanaka
Thanks Conanski, I wasn't sure all the wiring was the same. Since it is I will be changing out the computer.
**Would the 5.0 computer control the windows/locks and push button 4x4?
The 93 / 5.8 cab has Power Window and locks & Push Button 4x4
The 94 / No power windows or locks and 4x4 shifter
I tranny on the 5.0 is shot and am hoping the tranny from the 5.8 will fit (Not Sure if it will bolt up)
Old May 24, 2009 | 09:24 PM
Conanski's Avatar
Conanski
Yes the 5.8 tranny will bolt up but be sure to use the correct flywheel/flexplate for the 5.0 and whatever tranny it is because the motors are balanced differently.
No the computer doesn't control the 4x4 or powered options.
Old May 24, 2009 | 09:26 PM
Conanski's Avatar
Conanski
Need more info. Are the trannys in both trucks the same? Does either truck have mass air?
Old May 24, 2009 | 09:57 PM
Killa-Kanaka
Thanks
Conanski
