Sponsored by: Real Truck
which leveling kit
Old May 23, 2009 | 06:31 AM
POWERSTROKER07's Avatar
POWERSTROKER07
which leveling kit
im looking to put a 2 inch leveling kit on my truck.07psd fx4. i was wondering if i need to just get the front spacers or the kit that does all around the truck? lookin for some input.thanx
Old May 23, 2009 | 09:30 AM
hubler13f's Avatar
hubler13f
I went with the tuff country kit. I know some guys frown on tuff country but I have had no problems with it. I went with the tuff country kit because it also came with 1 1/2" add a leafs for the rear along with 2 1/2" spacers for the front and shocks.
I like the factory rake so figured this would give me the look I wanted. I bought it through www.suspensionconnection.com I had to wait about 2 1/2 weeks for it because it was on back order but it was worth it.
I installed it myself in my back yard in about 3 hours and for right around $350 with shocks it gave me the look I wanted and I was able to fit 35's. It rubbed the plastic tire well a little on the drivers side at a full left turn but that was easily fixed with a zip tie. I have taken it off road and had no other rubbing issues.
Old May 23, 2009 | 10:27 AM
dougc's Avatar
dougc
I put the RDC 2.25 inch springs on the front and f350 blocks on the rear. Also upgraded to Bilstein 5100 series shocks on at all four corners-front shocks came with the springs. Glad I did the shocks all around; the back shocks were the blistein OEM replacements and were shot after 30k miles, which surprised me a little. Drives great now...not like my other car, but better than stock. I didn't check out your ride other what you said (7 PSD FX4)...is it a Crew cab? Short bed? just curious...
Old May 23, 2009 | 11:02 AM
cwearmout's Avatar
cwearmout
I bought the ProComp kit and everything lines up nicely. I'm now running 35/12.5/20 Toyo MT's and there is no rubbing.
Old May 23, 2009 | 12:23 PM
DAVE67FD's Avatar
DAVE67FD
Seeing as you have the 350 you most likely only want to level the front with the rear.
If it is low in the front as i would expect I would look into the ready lift. Check out readylift.com they make a high quality kit and guarantee stock ride quality.
Old May 23, 2009 | 01:56 PM
POWERSTROKER07
yea it low in the front..ive heard good things about readylift so im just gonna go with leveling out the front of the truck.
