5 speed slave cylinder
Thanks
Slowsix
1998 LWB 2WD
ZF in T18 out I6
Get a screwdriver, and pry the white plastic ring-looking thingy back toward the driver door. It is a quick-disconnect, and hooks the hose up to a rigid tube coming out of the throwout bearing hydraulic.
Eddie
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
>Any tips would be appreicated!
I'm not sure what setup you have,but here's my .02 on a 96 F-150 I did a couple of years ago.
When my slave began leaking a bit and started to lose it's bleed,I replaced it and the master cylinder at the same time.I bench bled the master cylinder and the haydralic line as one assy.You have to depress the check valve on the end of the line while pushing the piston in.Just like brakes except a valve instead of a screw.Make sure to keep the fluid level up during this whole process.After the trans was put in I bled the slave cylinder with a clear tube connected to the bleeder screw going into a glass jar with some fluid and someone inside pushing in the clutch pedal.Again just like brakes and making sure to keep fluid level up in reservoir or else all is for nothing.After all of the air is expelled you should have a decent pedal,not great but decent enough to use.Now here's the trick,at least on 1/2 tons.After you depress the clutch pedal let it up fast,do this about a dozen times in a row.Don't push down real fast or you can damage the slave,(too much pressure too soon=blown slave seal).This cycle may take a few times over the course of a couple of days but trust me any air will eventually leave the system and a good solid pedal will come about.
Just make sure the fluid level is never low enough to get air in the system during any of these steps.
Good Luck!
