85f150
Old May 22, 2009 | 05:03 PM
mateolop's Avatar
mateolop
85f150
My 85f150 starter keeps running after i turn key to off.Have disconnect battery cable,to stop it.Had starter check and its ok,pos cable get hot. Could use your help on this problem. thanks
Old May 22, 2009 | 05:48 PM
Emartinez's Avatar
Emartinez
umm.. id say check the location of the cable. make sure its not to close to anything to get that hot.
are you running the computer controlled ignition or Duraspark?
Old May 22, 2009 | 06:17 PM
redlightning93's Avatar
redlightning93
Sounds like your starter solenoid mounted on the passenger side inner fender behind the battery is hanging up. Try raping it good with something to see if it will release. Otherwise, you will need to replace it. This is very common on these trucks. Good Luck!
Old May 22, 2009 | 06:46 PM
bashby's Avatar
bashby
Yep, starter relay Or way less likely ign switch. Its the thing with 2 big wires and one small if you didnt know already
Old May 22, 2009 | 11:32 PM
mateolop's Avatar
mateolop
I like say thanks,to you all for your help.It was the starter solenoid that mounted on passenger side inner fender.Going buy new one. And again thank you all.
