Need a little help
Old May 22, 2009 | 12:00 PM
Vinford's Avatar
Vinford
Need a little help
Been helping a neighbour with his newly purchased 85 4x4 with a 6.9.
He was changing the glowplugs and found something on the back of the engine .
Its a round electric connection that plugs into another round connection.
It plugs into a thing thats screwed into the block on the back side of the engine.
Its fairly big and one black wire runs from it up through the firewall.
The rest of the wires seem to go into the main truck wiring.
Its unplugged right now and we are wondering what it is before we plug it back in.
Its on the back of the engine closer to the drivers side of the block?
I told my buddy that I knew the best diesel mechanics in Noth Americia and they would tell us.
He thinks Im joking but I know someone here will know.
Thanks ahead of time.
Old May 22, 2009 | 12:29 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Sounds like the Glow Plug Controller ...
Does it start ok when cold?
-Enjoy
fh : )_~
Old May 22, 2009 | 12:46 PM
Vinford's Avatar
Vinford
Doesnt start when cold.
Old May 22, 2009 | 12:47 PM
Vinford's Avatar
Vinford
Isnt the GP controller on the fenderwell?
Its screwed into the block.
I thought maybe some kind of pollution deal?
Old May 22, 2009 | 12:52 PM
jmmartin's Avatar
jmmartin
the fenderwell should be for the starter. back of the block is for glow plugs
Old May 22, 2009 | 03:03 PM
sportsmobile1988's Avatar
sportsmobile1988
Is it on the drivers side or pass. side?? If it's drivers side it could be the temp switch.
If pass side back by the bellhousing it's an oil press. switch. I gotta van though, It may be different.
Old May 22, 2009 | 04:19 PM
Vinford's Avatar
Vinford
Fenderwell not fender.................
The starter one is on the fender.
Old May 22, 2009 | 04:20 PM
Vinford's Avatar
Vinford
Old May 22, 2009 | 04:25 PM
sportsmobile1988
Yes. Is it on the engine at the rear on the drivers side (from the centerline of the engine) or the pass. side??
Old May 22, 2009 | 05:54 PM
Vinford's Avatar
Vinford
Why do you keep asking me what side?
Ive said drivers side 3 times now?
Am I missing something?
Old May 22, 2009 | 06:59 PM
Festus Hagen
Methanoholic
It's the GP Controller, The GP Relay is on the passenger inner fender, the one for the starter is on the fender.
-Enjoy
fh : )_~
Old May 22, 2009 | 07:51 PM
Vinford's Avatar
Vinford
ah ha its the controller?
So it has a relay (on the innner fender ) and a relay?
So if the controller is unplugged could it be by passed?
Theres a button on the dash.
Old May 22, 2009 | 08:01 PM
Festus Hagen
Methanoholic
Yup, It sounds like the Controller is bad so they went Manual with a button... Something I detest!
Don't push that button for any more than 10 seconds, if you have already the glow plugs are more than likely fried! ~$80 (=Approx. $80) a set.
Yes, The Glow Plug system on the '85 has a Controller on the back of the motor and a Relay on the passenger side inner fender.
-Enjoy
fh : )_~
Old May 22, 2009 | 10:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Glow plug controller, actually it screws into the coolant jacket through the drivers side head.
They have been known to twist off when you try to remove them which requires removing the head to get it out usually.
And they usually fail in the on position, so it burns the glow plugs out when it fails.
Last price I saw on one was a little over 100 dollars, down from the original price of 150 dollars.
Manual control is the usual option when they go bad, 1983 thru 1986 trucks.
Glow plug relay 1983 thru 1986 trucks.
Behind the passenger side battery on the inner fender well.
Trigger wire from the glow plug controller is the small purple wire, usually closest to the engine.
Old May 23, 2009 | 10:35 AM
sportsmobile1988
My bad...sorry, I was wrong.
