1978 - 1996 Big Bronco
replacing rear brake lines...
Old May 22, 2009 | 11:40 AM
blue&white's Avatar
blue&white
so. it happed!!! my 96 bronco xlt is leaking brake fluid outta the rear lines!!! after 206000 new england miles!!! so my question is, can i do it? do i have to drop the tank? it seems to be leaking at the connection on the hard line and the stainless braided part?? what tools do i need besides the twelve pack of beer?? thnks!!
Old May 22, 2009 | 01:41 PM
mprice's Avatar
mprice
I had that happen to my '95. I chickened out and had a shop try to duplicate the original I brought to them. I figured they'd use hard line and a bender and do it up all pretty and professional. Instead they hand bent on the soft stuff and only got close. You will need the tools to handle cutting and flairing the line but you can bend it by hand if you get the softer type. Watch out for the fittings because on mine they weren't symmetrical. I can't remember the details but I think the block on the axle has two different sized ports on it. It helps to flair and attach one end, preferable the wheel side, and then just work your way towards the block, bending as you go. Trim the excess, flair it and attach it to the axle block.
Old May 24, 2009 | 01:03 PM
blue&white's Avatar
blue&white
re: rear brake lines....not the problem....
this is really strange. after cleaning all the gunk off of anything that looked wet, there is no leak. the brakes are spongy and i traced it to a rear drum leak at the bottom of the wheel.. since i was parked up on a curb (typical bronco park job.) i am thinking the overflow vent on the rearend leaked all over the place since it is the only thing that is the color(reddish) on the pavement. i drove around stomped and on the brakes. the suspicious looking drum locks up prematurely. hmmm..... i know it isn't the gas lines. cuz it would have pissed all over the place and reeked of gas! i use synth three clear brake fluid so it must have been the rear end overflowing.......
Old May 24, 2009 | 11:00 PM
McLeod's Avatar
McLeod
Do you mean that fluid was coming out of the bottom of your drum. Sounds like a bad axle seal or wheel cylinder to me.
Makes it sound like a bad wheel cylinder, as axle lube would more than likely reduce the tendency for it to lock up.
With something as important as brakes, you really should investigate and not make such silly assumptions.
Old May 26, 2009 | 08:23 AM
mprice's Avatar
mprice
Gear oil and brake fluid should be pretty easy to tell apart. Gear oil stinks and is very slimy. Brake fluid has only a slight odor, doesn't have much slickness and will wash off with water. You need to pull the drums and get to the bottom of this. BTW, all DOT3 brake fluid is synthetic and always has been.
diehardstroker
Apr 16, 2013 06:26 PM
ospreyguy
16
Nov 9, 2010 12:10 PM
sundancer330
Oct 9, 2010 09:15 PM
chainsaw cowboy
Jan 25, 2010 09:56 AM
