'04 Air Suspension ? / Conversion
Old May 22, 2009 | 11:05 AM
shepster's Avatar
shepster
Did a search and looked though a bunch of question and answer, but didn't find what I was looking for.
I have the front and rear air suspension on an '04 and want to convert it over to standard. I know there is aftermarket out there, but does anyone know if I can go to the junkyard and pull the strut assemblies off and use them? Looking at the different suspension everything appears to be the same. Only difference on the upper control arm is the tab for the lever to attach to for the bag.
If this is possible how do I tell the computer that I don't have the air suspension.
Old Jun 8, 2009 | 10:10 PM
Flytyme69's Avatar
Flytyme69
Hey if you are interested I just bought a 03 Expedition EB and would love to install an air suspension, if you would want to swap my shocks/coil springs for your shocks/air springs that would be cool. As far as it not working after the conversion you should be able to turn the swith off at the drivers side rear cargo area...behind the little access door. You can also take out CJB fuses 20 (30A), 27 (5A), 102 (30A), 111 (50A). Just send me a PM if you are interested.
Old Jun 10, 2009 | 03:10 PM
shepster's Avatar
shepster
Are you looking for just the air shocks or the whole compressor, upper A arms lines and all. Where are yo located at?
Shep
Old Aug 23, 2009 | 01:17 PM
Flytyme69's Avatar
Flytyme69
Are you still interested in swaping you air springs and shocks for my coilsprings and shocks. Nathan
Old Aug 23, 2009 | 04:08 PM
shepster's Avatar
shepster
I am out of country right now and will not be back until mid October. I will let you know something then, time depending.
Shep
Old Aug 23, 2009 | 07:19 PM
Flytyme69's Avatar
Flytyme69
Ok sounds good...hope all is well.
