CLUTCH OR TRANNY?
Old Jun 24, 2002 | 01:02 PM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
I have a 94 Ford F150 strt 6 4wd with a 5 speed manual trans.
The truck will start, go into any gear without noise or hesitation, but when you let out on the clutch it does nothing. It does not try to move and the engine does not die.
Does this sound like a cluth problem or a tranny problem. It has a hydrolic clutch and the fluid level is good-no leaks.
Any suggestions would be helpfull?
Old Jun 24, 2002 | 01:31 PM
ringkong's Avatar
ringkong
CLUTCH OR TRANNY?
Try shifting into gear with out pushing in on the clutch.
Does it feel "normal" when you go into different gears? (I.E does it feel like it is actualy going into a gear?
If it feels like it is going into gear. Put it in first. get out and see if you can push it(don't forget to take off the parking brake.). If you can..... OUCH... if you can't... OUCH..
Old Jun 24, 2002 | 01:46 PM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
>It feels "normal" with and without the clutch.>
>I am at work so I will have to try the pushing this evening.
But just a hint, what does
"If you can..... OUCH... if you can't... OUCH.. "
Give me the bad and the worse please??????
Old Jun 24, 2002 | 02:11 PM
DIFFMASTER's Avatar
DIFFMASTER
CLUTCH OR TRANNY?
Sounds like the transfer case is in a neutral position.
Old Jun 24, 2002 | 03:30 PM
lanero's Avatar
lanero
CLUTCH OR TRANNY?
Man, do I feel stupid. I made a reply to the thread in the 80-96 forum. I never thought about the xfer case being in neutral.
OK, check the xfer case first, then look at my guess in the other forum.
Roger Lane
Old Jun 24, 2002 | 04:12 PM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
Well here it is... I am typing this for my hubby so forgive me if my "lingo" isn't quite right.
The truck can be pushed forward while in first gear. There are no unusual noises when this is done.
The throw out bearing can be manually moved through the inspection hole.
And he said something about being able to move the transfer case out of neutral and into gear manually.
Something tells me this isnt good.
Old Jun 24, 2002 | 11:15 PM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
Is there anyone else out there with any suggestions?
Old Jun 25, 2002 | 08:56 AM
ringkong's Avatar
ringkong
CLUTCH OR TRANNY?
>inspection hole.
So it was in nuetral?
If he puts it in 2hi and the trany in first.. he should not be able to push it.
I take it that the transfer case is an pushbutton type.
MAKE SURE THE TRANSFER CASE IS IN ANYTHING BUT NUETRAL
Old Jun 25, 2002 | 09:50 AM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
First of all thanks for the help your giving me.
I can change a clutch, but not the tranny.
It is not a push button T-fer case, it is manual.
In 2h in first gear, you can push the vehicle.
Old Jun 25, 2002 | 11:53 PM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
[updated:LAST EDITED ON 26-Jun-02 AT 00:54 AM (EST)]I have had several people lead me to believe that it is the slave cylinder which is internally mounted.
You said that I "should not" be able to push the truck in 2H in first gear, but I could. Could the slave cylinder do this.
I can get the part locally in stock, but wanted to check before I go tearing it apart
Old Jun 26, 2002 | 12:27 PM
DIFFMASTER's Avatar
DIFFMASTER
CLUTCH OR TRANNY?
Ok, does the driveshaft spin when you let the clutch out while in gear? Slave has nothing to do with this problem. Can you tell me what you were doing before you parked the truck last, also try putting it in 4wd and see if it moves. Is it possible someone stole your driveshaft?
Old Jun 26, 2002 | 02:27 PM
lanero's Avatar
lanero
CLUTCH OR TRANNY?
To check the slave, look through the inspection hole while someone works the clutch pedal. The TO Bearing should move about 1/2 to 1 inch when the pedal is pushed in.
Besides, if the slave was not working, the clutch would never disengage, making it imposible to put the truck in any gear while the engine was running.
Like someone else asked, what was the last thing you were doing before it stopped working?
Roger Lane
Old Jun 26, 2002 | 04:11 PM
1SHAWNJ's Avatar
1SHAWNJ
CLUTCH OR TRANNY?
[updated:LAST EDITED ON 26-Jun-02 AT 05:19 PM (EST)]Not Exactly sure.....I bought the truck as is and was told the clutch was out. The guy said that he was driving down the road and the truck died and when he pulled over and restarted it the clutch was gone and he had it towed.
I know the guy, and he is pretty honest????
Yes the drive shaft is still there. There is no movement in 4wheel drive. The drive shaft does not move at all, but the TO bearing does ( I tested it by attaching a rod to the TO Bearing and when I pushed in the clutch it poped it out so there is movement)
Input shaft maybe.
Old Jun 26, 2002 | 05:29 PM
DIFFMASTER's Avatar
DIFFMASTER
CLUTCH OR TRANNY?
Is there any funny noises coming from the tranny or t-case? It could be the input shaft in the tranny, it could snap outside the front bearing and make little or no noise, could also be in the t-case, I would say that is the next step, pull both units out and decide which one is not transmitting power.
Old Jun 26, 2002 | 09:44 PM
kspilkinton's Avatar
kspilkinton
CLUTCH OR TRANNY?
If the guy said the clutch was going when you bought it and you noticed a considerable mount of slipping when you let out on it, then it probably is the clutch. Try adjusting the clutch per a reference manual for the year range that your truck falls into. Some clutches are self adjusting. Eventually the clutch will get to a point where the pads don't engage the flywheel and your symptoms occur.
How many miles are on the truck/clutch? Things to think about. Some people get bad clutches, or crappy vehicles. Others just end up driving the poor thing in a manner not condusive to manual trannies.
When did the symptoms occur? When you first started it one day? While it was in motion? Was it stopped? Did it act funny when shifting it? Give us some more info and we'll have it fixed. Either way it sounds like the tranny is going to be dropped for a clutch job or a partial rebuild.
-Kerry
