Need Torque Converter Opinions
Old May 21, 2009 | 12:47 PM
tojoski's Avatar
tojoski
I have an 01 2wd with 139k with the infamous rattling torque converter.
I have been considering options to replace it wanted the opinions of you guys.
I first considered using a 6.0 tc, but John Woods no longer sells the adapters needed to make it work.
Option #2 are these guys I found on ebay:
FORD 4R100 DIESEL 7.3L POWERSTROKE TORQUE CONVERTER:eBay Motors (item 260350430045 end time Jun-20-09 10:27:26 PDT)
I know its risky, they haven't been selling too long. I gave them a call and talked to them a bit and they seem like a reputable outfit.
They have an actual office in AZ, they aren't a ebay-only seller.
and.. from looking at prior auctions it can be had in the $300 range..
$500 or less is my budget, and I have PMR 's so I don't expect I'll be getting too crazy with my mods.. maybe some PHP tuning one day.
I don't do much towing either, I have a 24ft Camper I pull a few times a year, thats about it.
I searched threads on this back to 06' and found a few suggestions, but never a follow-up good or bad...
except the recent bad experience with the oregon transmissions seller on ebay...
Option #3 would be a factory ford replacement.. but I assume that one day I'll be dealing with the rattle again?
Old May 21, 2009 | 02:36 PM
DieselCamper01's Avatar
DieselCamper01
Have not needed to do this but here is a bump.
Old May 21, 2009 | 03:25 PM
superduty4x4's Avatar
superduty4x4
Joe, I thought the 6.0 TC was a bolt-in, the one from the 6.4 is the one that requires an adapter. I would verify that with either JW or BTS and go from there.
Old May 21, 2009 | 03:47 PM
makomaker's Avatar
makomaker
Suncoast converters...recommended.
Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL
Old May 21, 2009 | 09:16 PM
tojoski's Avatar
tojoski
Originally Posted by makomaker
Thanks for the suggestion but they want $1295 for their converters...
Old May 21, 2009 | 10:06 PM
danskool's Avatar
danskool
Go Bills !
I had the same problem. I went to a local shop. I didn't want to go to expensive. My local shop put in a TC .. $650. So i decided to let them do it. The local shop, i found out later that they did work for the ford dealer up the street when ford got booked. They used, i believe Dayton/dayco. HD ford reman or something along them lines for TC's.. My truck has been flawless since. Been about a year now and not one problem. Pulls the 5th wheel perfectly. I was going to put in an expensive one but after getting that price and the warrentee and asked around. My shop had good reps.. So i went this way. like i said, Been super so far. I think the tc was $300/400 if i wanted to buy it to do my self. Plus trans fluid and filter. When i picked up the truck i was so impressed how quiet it was. That rattle was gone.. The converter they took out was something other than ford from the previous owner.. It was turquoise in color. And Trans was marked with " R & R J.W. 8-16-04" So that after market TC pooped out.
This was the one the previous owner put in. A pic of the rattle junk.
Old May 22, 2009 | 08:17 AM
tojoski's Avatar
tojoski
Thanks for the info, I'm leaning towards giving the guys on ebay a try..
Old May 22, 2009 | 03:22 PM
aklim's Avatar
aklim
I'll take Door #3. Your trans is no spring chicken. Don't put an expensive TC behind a worn trans. When the trans fails, it could dump debris into your expensive TC. At that point, 2 options remain. Throw away the TC or cut it apart, clean it, weld it back together and then rebalance it. $$$$
Get a cheap ford unit, when the trans dies, get a good one like BTS and forget about it.
Old May 22, 2009 | 05:56 PM
Mid_Mo_F100's Avatar
Mid_Mo_F100
Are the OEM's really that cheap? I priced one at my local stealership and they quoted me $600. For that money you could get the after market one, not a high dollar PI or anything, but a decent one like the ebay one or one from Racer X. Did they quote me wrong?
Old May 22, 2009 | 06:00 PM
aklim's Avatar
aklim
I think you can get them for $200
http://www.trademotion.com/partlocat...layCatalogid=0
Old May 22, 2009 | 08:12 PM
Mid_Mo_F100
I thought those were for gassers.
Old May 23, 2009 | 10:52 AM
aklim's Avatar
aklim
Doesn't say but I'm sure a phone call will clear it up
bsiebert
Jun 18, 2016 12:27 PM
00Dave
Sep 17, 2010 04:16 AM
ivanribic
Offroad & 4x4
24
Aug 22, 2004 10:03 AM
THE HEAP
Feb 20, 2003 07:30 PM
rockcrawl
Jan 8, 2000 08:33 PM
