Excursion Noob!
Old May 20, 2009 | 09:50 PM
motopsyko32's Avatar
motopsyko32
Excursion Noob!
Just bought a 2000 Excursion Limited v10.
So far, love it... a few things I have to fix here and there... Drivers power lock doesnt work, cruise control does not turn on, overdrive button does not work.
Is there a way to check online if my VIN has had any recalls done to it yet? I know there are 4 recalls that may apply. Can I check this without calling Ford? Thanks for the info!
Old May 20, 2009 | 09:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
You can post your VIN in the "OASIS REQUEST" thread that is on top of the Super Duty forum. That report will tell you what has been done and if anything is outstanding.
Sounds like you need to go through the fuse box and check for bad fuses, huh?
Old May 20, 2009 | 09:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
Old May 20, 2009 | 10:06 PM
EXv10's Avatar
EXv10
Do the tin foil thing on the actuator. See post on it in here.
motopsyko32
yeah I can start in the fuse box... havent started any troubleshooting yet. Just got her home tonight
Old May 20, 2009 | 10:09 PM
TeamMudd's Avatar
TeamMudd
welcome to "Club X", i'm a new member myself. not new to the type of truck, but i got a new to me, Ex at the beginning of this month, and have loved every day of driving it. it was a great upgrade from my 92 Z71!!
Old May 20, 2009 | 10:11 PM
motopsyko32
i am upgrading from a 94 F150 XL
Old May 20, 2009 | 10:13 PM
motopsyko32
one more question. So the dealer that sold me the truck did not know the door code to unlock the doors. How can i reset this?
Old May 20, 2009 | 11:20 PM
X-Hibition's Avatar
X-Hibition
Read recent threads...
https://www.ford-trucks.com/forums/6...er-method.html
Old May 20, 2009 | 11:33 PM
EXv10's Avatar
EXv10
I don't think the 2000 has the code anywhere on it. Use this method;
Weak security in our daily lives@Everything2.com Click on WEAK. Re-setting should be in your manual.
Old May 21, 2009 | 06:34 AM
motopsyko32
Thanks all
Old May 21, 2009 | 07:01 PM
motopsyko32
So somehow today playing with the factory alarm controller I was able to remote start my truck. I have NO IDEA how I did this. Is there a secret, g14 classified sequence that causes this?
Old May 21, 2009 | 07:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sounds like you have an aftermarket remote start. Find the controller under the dash to determine the brand and then find the place around who sells those so that they can get you the info on it.
Many a problem has been posted here that stems from an aftermarket alarm or remote start whose installation has been cobbled together by two semi-drunk guys in their garage.
Old May 21, 2009 | 08:08 PM
motopsyko32
here is my fob. is what you are saying that an aftermarket remote start was incorporated into the factory alarm?
Old May 21, 2009 | 08:37 PM
motopsyko32
so I went through the fuse box specifically checked fuse 6 which is the cruise control/overdrive fuse (both dont work). The fuse is not blown though...
