I've never been around the '75-'91 Econoline Vans enough, but I do know they do share some parts with our Trucks, has anyone looked into this? maybe by 1991 Ford had a improved Fan/Cage setup that might work in our Trucks? either a direct bolt in, or possibly some minor modifications to make it work? just thinking about the Econoline Vans and some of them were Club Wagons, so they had people in the rear, so I would assume Ford would've had a better blower setup by the 1980s?
I'm interested, my Truck's Blower howls very loudly, I was thinking of oiling it, but if there is a fan upgrade, I might consider it over just buying another blower motor, anyways if no one has looked into the possible Econoline connection, then I might have to eventually, anyways this isn't the highest priority for me on my list, so I wish everyone luck,
I realize this thread is old, but I was wondering if anyone ever came up with a solution to get more air flow out the vents. Like using different/newer style squirrel cages?
My daughter took my truck yesterday and then came back telling me the A/C didn't work, I got in to check it out and sure enough the blower motor isn't coming on at all, at any setting. It had been howling somewhat on the higher settings sometimes, not all the time. But now, I got nothing. I knew I was eventually going to have to replace the blower motor due to the howling/squeaking, so replacing it with an upgrade that will move more air would be great.
Thanks,
EDIT: The main issue I see with the newer style squirrel cages and motors is that the backs are sealed, not open the way ours are allowing it to suck air from the box and blow it out the vents.
I just changed my heater core which was leaking on my 77 F250 , no AC.
This truck had low velocity out of the vents as well , I figured maybe the heater core was stopped or an obstruction in general.
Turned out to be the last person to change the fan wired it backwards.
The squirrel cage blades must cut the air on the outside when turning.
Mine was wired green as + .
Just an FYI for those having the air flow problem , this cured mine.
Few notes, old thread... I restored full flow to my 87 ranger by replacing the resistor and wiring a relay into the circuit to make sure I had a solid uninterrupted +12v to the blower motor.
WORLD of difference. Maybe it will help on some of these other rigs as well?
I had an 85 Nissan Sentra that could really move a lot of air, but I don't know if it was because the car was small and therefore the vents were too making the velocity higher, or if the blower actually moved more air than the Ford one. I've even considered making my own with wider blades once I get my lathe set up. But it would be easier to just find a blower that can move a lot more air.
I have the same issue with my 1978 F350 Crewcab. I have a new switch, but on high it barely put s aut air. If I run a wire direcy to the fan from the battery, the fan puts out great air. Did Ford put in different resisters? Are there different fans? The fanwas replaced by the previous owner.
FYI: a few trucks I have worked on this year had the wrong fuses in the fuse box for the heater, one had a 10A instead of a 30A, the others had 20A instead of 30A, I put the proper fuse in and the blower moves a great deal more air!
Upgraded my wiring harness using the AAW kit ('79 Bronco). The AAW AC/heater circuit is only rated at 30A, where it's 35A from Ford. This prompted me to do what you did, with a relay. I've got a 70A relay being fed power directly from the battery via 6 AWG wire and delivered via a 50A circuit breaker. Definitely hoping it will help.
Never thought about replacing the resistor pack. I suppose they wear out in time too...
I finally got my truck running and tested the AC out. Like I mentioned in the previous post, I upgraded the power to the HVAC system via a dedicated 6 AWG feed from the battery, 50A circuit breaker, 70A relay. I am not kidding, at full tilt the interior of the Bronco is like a tornado with all that airflow. The AC blows nice and cold even in my truck which has no carpet or insulation. I did not replace the blower motor resistor pack, just updated all the wiring and cleaned out my stock evaporator housing, fixed some seals that were dilapidated, etc. Tornado.
Shaker 666, I've got the wire, relay, and fuse block to make this upgrade. My only question is where does the "Switch Ground" wire connect? Thanks for any help you can give me. Jim
Are you wiring up an AAW harness kit or working with stock wiring?
