1990 aod
Old May 20, 2009 | 06:26 PM
jr32560's Avatar
jr32560
1990 aod
okay guys does the aod have a drain plug on the converter? i know the e4od does-gonna drain and fill the trans -started slipping coming out of overdrive -checked the fluid to see if it was low and it's showing over full and bubbly on the stick-like air in the fluid-I remember hearing about this problem but my old mind don't remember-I was thinking it might be the filter has dropped and sucking air-any and all help is appreciated
Old May 21, 2009 | 07:32 AM
jr32560's Avatar
jr32560
no transmission gurus on here?
Old May 21, 2009 | 07:50 AM
l-m tech's Avatar
l-m tech
yes it does its going to be sticking out of the front of the converter instead of the side like the e4od.
