I have a 2001 powerstroke and it will not start. I know its getting fuel for i pulled the filter cap off and it was evident. Im no diesel mechanic and i just have no idea! Any ideas and by the way if somebody has a fuse diagram for this truck i would love to see it???
More info needed my man...
Does it turn over but won't start?
Any smoke out the tailpipe?
Is your oil clean and full?
Batteries charged up?
Battery connections clean and tight?
Did you recently buy new fuel (could be bad fuel, water in fuel)?
Get back to us and we can help you get it going again. By the way, the 99-03 7.3L forum is the best place to post questions about your truck, you'll get many more responses because more of the 7.3L experts will see it.
Welcome to FTE, stick around as there is a ton of good information that can be learned here!
