Rear fender bolts 1948-52
on
1 Post
Can someone please tell me how many bolts are used to attach the rear fenders to the bed sides.
I am using a bed from a 53 (holes filled because they did not match the fenders) and fiber glass rear fenders (did not come pre drilled).
If someone could give me the number of bolts and spacing or even direct me to a photo that clearly shows the location of the bolts, it would be much appreciated.
Nick
Nick
Northern Classic Trucks has the weld-in-studs, just like OEM for 50 cents each. Grind the head off and they fall on out.
The underside of the flat head has three dots in a triangle pattern. Put the bolt in the hole, and zap it - the three dots weld themselves to the bedside and you're set!
~Jason
~Jason
