I just had some front end hub/ball joint/tie rod work done on the Beast, a 1996 F250 XLT.
I can't turn the beast anymore! It is really hard to turn, like when a vehicle is low on power steering fluid.I checked the fluid and if anything, there was too much fluid. It was really dirty fluid though. Should I change it out?
And if I have to turn sharper than normal, but not really sharp, I hear a noise and it seems like something is sticking and than trying to drive home, it pulls to the left. Sometimes hard!
Help!
WOW.. Go back to whoever serviced the truck and demand your money back. You definitely don't want them working on it again because they clearly don't know what they're doing... a vehicle should work better after service not worse.
