Low oil pressure
Either way if you dont know my beast it is a 7.3l idi and since my oil change it has been getting less and less oil pressure. Now i have checked and rechecked my oil levels, according to the dipstick it is good, anyone want to measure theirs and post up a measurement for me to check to make sure the correct dipstick in in it? thanks if so. Cold it is ok, not great but within norms, i need to get a mechanical one and ditch the dash display. After awhile of driving it gets lower and lower. usually when you rev the engine it will boost up not go down. Thoughts on this?
Thanks
If you want to know what you have you really need an aftermarket gauge.
Mine did what your is doing about 100 miles from home on Sunday evening.
What was worse, I had just installed a reman engine the week before, 7,000 dollars on the line.
